Oil Change Question??
grillo
Car: g35 coupe
Hey guys.. I have a 04 with 40k on it i am thinking to go to synthetic oil like royal purple.. Do i have too many miles to start with synthetic???? What weight should i go with with 10 w 30?? What kinda filter should i use if so and how many quarts should i use???? And how many miles should i change the synthetic oil??? Thanks...
By the way whats up with my brakes i can have my rims clean 20 mi lator there full of brake dust??? Guess im stuck cleaning them every day lol
Modified by grillo at 4:02 PM 7/23/2007
FamilyZ
Car: 350 gt
you can start synthetic when ever (better). 10 30 should be fine. I use mobil 1 oil and filter. Seems to work fine. I usually change every 3000 miles, but can probabably go up 10k to 15k before changing ( I wouldn't ) as long as ur not racing everyday.
You wouldn't happen to be in the marines ever would ya. I just remember a guy that sometimes called himself grillo.
Welcome to Nico!
grillo
Car: g35 coupe
no.... im from jersey.... Thanks for the info
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Brake dust is because of the compound of the oem pad. Switch out the pads for some Project nu ms pads or satisfied pads.
grillo
Car: g35 coupe
thanks for the info
abdoman
Car: 2006 G35
I checked with my local dealer about length between oil changes when using synthetic. They told me that Infinity will only allow 7k mi on the synthetic oil or you will void the warranty. Does anyone else know if this is true? I plan on changing my oil every 5k using Mobil 1.
joe603
Car: 2014 Durango R/T
5k or 6 months are good numbers for synthetic oil. Royal Purple is one of the best lubes available~!
grillo
Car: g35 coupe
how many quarts does the g use and any filter should do????
szh
Car: 2018 Tesla Model 3.
grillo wrote:how many quarts does the g use
This is in the back of your Owner's Manual ...
grillo wrote:and any filter should do????
Well, yes, but some are a lot better than others. In your shoes, I'd stick with Nissan/Infiniti OEM filters. If you get them from http://www.everythinginfiniti.com, they should be relatively inexpensive. If you do your own filter replacement, remember to get the copper drain plug washers too.
Z
