Oil change help please!!!!
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
yaro07
hi im here for my dads car. He has a 2003 Nissan Altima and nedds to change oil in it? He needs to know which oil should he use it, because he talked to other guys in stores and they recommended different oil brands. Please help me
naed240sx
Car: .....
It doesn't matter too much.
Synthetic is better, but if you switch to synthetic, you should never go back to regular, so you are kinda stuck with it.
As far as weight (10w30, 5w30, etc), use whatever is reccomended by the owners manual. Brand?
Castrol, Mobil 1, and others are good brands, but once again, brand isn't that critical. What is more important is to use good filters, use the correct amount of oil, and do frequent oil changes.
yaro07
ok does anyone with an altima knows what the owners manual recommends because i dont have mine
yaro07
please somone help me
bigboy9295
Car: 2002 Nissan Altima
10w30 is what is recommended. I personally use Mobil1
94altima
I checked the Pennzoil book for the recommended oil viscosity of the Nissan Altima, and the recommended oil is 5W30.
For the oil filter, you can use Pennzoil PZ 109, or you could go to Wal-Mart and look in the catalogue of Fram Filters.
You can use conventional or synthetic oil. It's just a matter of personal preference.
As a comparison, 10W30 is a little thicker at room temperature, but at operating temperature, the viscosity of the 5W30 and 10W30 is almost the same.
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
I use valvoline durablend on both of my cars. 10w-40.
Return to “3rd Generation Altima Sedan (2002-2006)”
