TaiLuu wrote:Don't Add To Much Oil btw. If you add more oil then the car needs you will screw up your motor. Adding to much is just as bad as having No oil.
The condition is called hydro lock. It occurs when a liquid displaces a gas. Since liquids are not easily compressed, it can place significant strain on components.
Example: Fill 2 balloons, one with air and one with water.
- Step on the air filled balloon and it will take a fair bit of pressure to pop it. Reason: the gases within the balloon compress and take up less volume. You need to add more pressure to overcome this and burst the ballon.
- Step on the water filled balloon and it'll immediately pop. Reason: Liquids to not compress, instead it immediately transfers pressure to the balloon which pops.
Excessive overfilling of engine oil can be a serious issue. Follow the recommended capacity and oil level check procedures in the manual. Nissan is very specific on how to measure engine oil levels:
CHECKING ENGINE OIL LEVEL
1. Park the vehicle on a level surface and apply the parking brake.
2. Run the engine until it reaches operating temperature.
3. Turn off the engine. Wait more than 10 minutes for the oil to drain back into the oil pan.
4. Remove the dipstick and wipe it clean. Reinsert it all the way.
5. Remove the dipstick again and check the oil level. It should be within the range (L to H). If the
oil level is below L, remove the oil filler cap and pour recommended oil through the opening. Do not overfill!
6. Recheck oil level with the dipstick.
