Oil change from hell
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
So yesterday I went up to the shop where I have my car. I thought to myself better change the oil now since it's been a while. Step 1 drain oil, step 2 take off oil filter......... Yeah didn't get past that part so easy. I had to pull the filter housing off the car and put the filter a vice to get it off housing. Anyway to my point I see some cracks in the casting but I'm not sure if these are factory since I never really paid attention to it in the 1st place.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Looks like they're from vibration... Considering I can see them EASILY in the first pic from decently far away, they're kinda bad. I still doubt they'll cause you any issues, though, as long as they don't get any bigger...
Ramius83
Car: 1995 240sx SE
Just eliminate the cooler housing and install a block oil filter stud.
Dirty Dee
Car: 1989 240sx
mine has the same thing going on :eek
Carl H
i think those are just casting marks.
USsil80
tape up the hole... pour some water in it and see it leaks... if yes... replace/remove... better than using busted parts
