CYO44Baseball32CYO44Baseball32 wrote:Sense I've heard such good things about royal purple I decided to use it. Figured it would have cost over $100 at a shop to change it (If anyone knows the exact cost let me know I'm curious) with royal purple I did it myself. $42 with a napa filter and 5 quarts. I bought $32 rhino ramps because most of you know how low low my car is (350z s-techs ftw). I was surprised that Nissan actually put something in the car in an easy to access spot , unlike the headlight bulbs. Filter was easy to take off too, didn't even need a wrench. Old oil wasn't that dirty and the car had driven 1,000 miles the last day over 15 hours from Florida and the last oil change was 5,000 miles ago. I think we can hold out with our cars to 7,000 with no problems if you have full synthetic.
There are 4 10mm bolts that a hand tools can remove easily. I just drove the car onto ramps I bought for $32 at the auto parts store. My car is slammed and I still had room to work. Once those four bolts are off just fold back the small section of the cover and you see the drain plug and oil filter.G37 Man wrote:Got a question on changing the oil on the G37,from seeing how it was changedon my G37,isn't there a cover on the bottom of the G37 that needs to be removed before you can get to the oil filter? Looks to be a pain in the *** unless you have the car on a lift with room to work.
The whole thing is after 5,000 and one trip of over 1,000 miles straight, the old oil was still good. The old oil is what ever infiniti uses for oil changes, so I think that oil would have been fine for 7,000 and the royal purple will be fine for 7,000.rn79870 wrote:I think the downside is people thinking it is healthy to extend the oil change periods way beyond the 3ooo mile mark, not the oil itself.
I take the whole fiberboard shroud off using a portable electrical drill with a 1/4 in adapter for the 10 mm socket to remove the bolts. It only takes a couple of minutes to remove it completely and I clean it off. I pour the old used oil into plastic jugs and drop it off at Pep Boys.CYO44Baseball32 wrote:
Damn way to make my whole operation look cracker jack lol. But very nice set uptelcoman wrote:
The old pink plastic shower curtain that the wife told me to take out to the garbage makes an ideal cover to wipe up any spills on my concrete driveway.
I generally do my tire rotations every 5k miles while changing oil at the same time.
Telcoman
Modified by telcoman at 10:30 AM 5/31/2008
Modified by telcoman at 10:32 AM 5/31/2008
What???rn79870 wrote:Synthetic oils have been known to seep into your transmission and cause your neuteral gear to seize (if you have an AT) or they can cause the pre-lubrication on your pressure plate to gel and not work efficiently. They also are suspected of causing premature wear to the freeze plugs in the combustion chamber.
Edited... I found an article that reports pistons are often found to have crowns after teardowns when synthetic oils were used.
Tampa G35 Sedan 6MT wrote:I think you have to use regular oil for the cars first 10k miles then you can switch to Syntetic.
I use Mobil 1 15,000 mile extended preformance.
Love it and only have to change my oil once a year or every 15,000 miles. Even at 15000 miles the oil is still clean in my G
3k mile change X5 =15k miles @ 20 bux each....100 bux
15k mile change 60 bux at walmart with mobil 1
40 plus bux to IRA or 401k
oh yea and I get to have someone do the work and i sit in the A/C
That is the only thing my father ever tought me. He said one day "son today i am going to show you how to change the oil"... I thought wow dad is going to show me something. We got in the Jeep and drove to the 10 min pensoil and said "this is how you change your oil.... Get a good jop so you can pay people to do what they do and you can get paid to do what you do."
I still live by that to this day and me and my father don't have a good relationship.
DJ
$80 per axle with brakes....I just called up pepboys to ask how much to change spark plugs on friday. $100 just to change the plugs i had previously purchased. I said screw that and changed them for free in like 30 min.badutahboy wrote:
Lol.. I definitely agree with your dad's advice when it comes to oil changes.. It's hardly worth your time to save $15-20 bucks while wasting an hour under your car and dealing with disposing of old oil... However, most other maintenance stuff I do myself.. brakes in particular. It drives me nuts that most everyone charges $80+ for brakes when you can do them in your driveway for $25-40 and 20 minutes of your time.
