Oil catch can/tank.
Nissan 350z / Nissan 370z general community discussion forum
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
Oil catch can, is it a bad investment? Pro's and Con's? i'm considering...
dasoupdude
Car: 2005 Nissan 350Z
in my opinion i think its rather a good investment than a bad one, when i took my oe upper plenum off to replace it with the kinetix one i saw all the sludge gross build up around parts of the intake from "blowby" coming from the crankcase..their inexpensive,especially at that price of $60, you can even make your own custom one too but i was too lazy so i bought one. they all perform the same so don't think the 200 arc one is going to do any better than the Greddy catch can. grawl.
rmezz13
thanks for the info, i already bought one and i think it effs with my vacuum pressure so i think i may get rid of it. Plus its been like a month and i don't think there is anything in the can yet.
dasoupdude
mess with vac pressure..how so??
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
no it doesn't effect your vac pressure if it's hooked up correctly
evildky wrote:yup, no preformance or economy to be gained form a catch can, it's just a fancy PCV system, looks different does esentially the same thing just catches any oil as opposed to buring it in your intake charge, they are far more useful on forced induction cars as they have more blow by, higher crank case pressure and more air to vetn off, and if you are getting more than a few drops here and there in your catch can there is somethign wrong with your engine
rmezz13
yeah its weird, acted like i had vacuum issues when i ran it one day (when i posted that) and then i checked all my lines and the next day it was fine. Kind of odd!..... Anyway, yeah its not doing anything to the vacuum, but its also not catching anything. One day when i have a whole 5 min. i will probably take it off. Looks kind of cool though.
dasoupdude
it won't catch oil rightaway, first you have to notice the hoses getting all grimy and brown, and the brown color works its way to the can
evildky
06 Nissan 350Z GT
again, it shouldn't get much ofif any oil on an n/a, if you start getting oil you have an engine problem
Return to “350z / 370z Discussion”
