blkvrtswp wrote:Ah, sorry - I should have noticed the KA-T in your profile blurb. If it's not stock turbo, I really do not know what to recommend. Someone else will have to comment on what to do with PVC, ports etc. on KA.
I know having vacuum pulling on the crankcase is a good thing - better than just open to atmosphere - and much better than having it sealed up.
If you are getting only minor overflow/blowby like you have it, you could just get a pretty, cheap $40 eBay can with a filter on top.
reading what you wrote, its obvious that you know how the pcv works… I really do not want to vent the pcv or vc to atmosphere… IMO that really does nothing good for the oil.. Sure its vented so that it does not re-enter into the combustion chamber but at the same time its really just sitting there doing nothing… The vapors may be pushed up to the oil catch can by extreme crankcase pressure (wot) but at idle and normal cruising, i don't see how the blow by can make its way up, i am not seeing it..
Again the whole point to the pcv is to extract the crankcase air to help preserve the oil to last longer, and if we vent both those to atmosphere, we are not "technically" extracting the air from the crankcase..
My setup was to take the pcv OUT… put in an open air fitting (3/8npt to hose barb) and attach a hose to it and take this hose to a catch can… then from the catch can run a hose to the turbo inlet… Then take the vc and place a breather on it…
we know that the turbo spins at idle, cruise and under boost…. Which means a constant suction… which means if the turbo is spinning and sucking out crankcase air, that means the vc will be allowing IN fresh filtered air as designed by factory…
that is unless the turbo is not capable of pulling out the crankcase air at idle or cruising speed..?? The last time i took off my intake filter and put my hand to close off the pipe, it sucked my hand in pretty good and when my hand closed that pipe, that motor about died…!!! So i would say that it should have enough suction to pull out the crankcase air which allowing the vc to suck in..
