bernabe wrote:I got my second oil changed and found out that my oil level is just above the E level of dip stick after travelling 600k, definitely thers's a problem on it and my dealership always deny that there's a engine problem...I need your opinions fellow roguers pleeeaaaseee
You obviously have a problem, no question about it. My advice is to document every detail, so when you report it to the dealer you will have a response to all their attempts to dismiss you claims. For example, record that after your last oil change, 600 km later oil level is on E, added a quart. Drive it another 1000 or whatever and again document the results. then take it back, let them know there is a problem that you've been documenting for several thousand kilometers IN DETAIL and that they need to address it. The most common mistake is that owners don't have very good details to report so the dealer assumes the problem is just being imagined. Walk in there with good documentation and they'll take care of you, they have ways of checking for excessive oil consumption (ex. compression test etc..).
Mine has NEVER used so much as a single drop of oil, it stays on full permanently, and I drive many short distance trips, hard on the car, and I'm not very careful about how I check the oil, nonetheless it's always topped right up and crystal clear. So don't accept anything less than this. Good luck.
