zallow »
https://forums.nicoclub.com/zallow-u8316.html
Sat Oct 18, 2008 2:33 pm
Hi there,
I recently bought a used SOHC from some guy and it was burning oil pretty bad. So i got another one from some friend that was running it before with no problems at all. I even did a compression test on it and it was 170-180 across the board. When i installed it in my car, it was burning oil like mad and still is! At first, i thought it was the oil residue in the manifold still burning off. I used a ton of throttle body cleaner and was still burning oil.
Waited a couple days and now it's gotten to the point where the car is almost undriveable when it's cold. It hesitates really hard until it gets warm. Then it doesn't smoke so bad and drives fairly ok. Same thing was happening on the first engine i bought off the first guy but the hesitation was way less aggressive. I filled up the oil after installation and it took only 4 days for the dipstick to get dry as a bone. I was floored! And i know it's burning all of it, because it smokes blue like crazy and i'm not leaking oil anywhere under the car.
I had done a timing chain kit replacement and head gasket and head bolts on the first engine. So when i found out it was burning oil, i got really pissed on spending the money to find out i had bad rings or bad valve seals. Hence why i got the other engine off of my friend that was running fine. But now that it's in my car, it's absolutely horrendous and the only thing i did to that engine, was swapping my timing chain kit over. I know my friend wouldn't screw me over like that especially since he knew my situation with the first engine, so i'm really stumped here.
To my knowledge, there's only 2 way you can burn oil and it's thru the piston rings or valve seals. I didn't touch any of that on the 2nd engine i got. I didn't even touch the head. Is there something i'm missing here?
