autotech43 »
https://forums.nicoclub.com/autotech43-u4010.html
Sat Feb 01, 2003 7:07 am
There ARE a few of the new Q engines using a small amount of engine oil, and Q45 tech hit the nail on the head with this one. The problem is the rings are taking longer to seat, and Infiniti will be concerned when addressing the problem of the mileage on the vehicle with this concern. Infiniti will require an oil consumption test from a dealer before taking any action on the matter. From Infiniti, an engine with 10,000 miles or more still using engine oil, they will look at that issue seriously, compared to an engine with just a couple thousand miles. It reminds you of the older days when overhauls were quite frequent, (what type of rings to use)? I remember some techs trying to get the chrome style piston ring to seat, and if the cylinder wall and bore wasnt perfect, they may never seat. The Hastings steel ring use to be one of my favorite, regarding accelerated ring seating!But that is then and this is now. I know one of our Q customers is a traveling salesman, and he also has mentioned and oil usage a period of the first two oil changes, but remember, an engine that runs a CONSTANT rpm wil require more miles to seat piston rings, as to an engine that gets some stop and go runs during break in. There was a good thread posted regarding engine break in which has some useful information for folks.I will be going to the FX35-45 new model training next week, I will ask a few questions regarding the Q engine and also see if other techs from other states and dealers are running into that concern as well.I would recommend letting the engine sit for a short period, or say check the oil the first thing in the morning to let all the oil drain back to the pan, you would be surprised on how much oil that particular engine holds on the top side!I am currently performing a consumtion test on one of our customers new Q's, we will see how things go.Good thread, and I also would be concerned!!!
