Postby 240sxed » Sat Aug 20, 2005 11:35 pm
I am doing an fmic setup, so I thought it'd be a good oppurtunity to reroute the hoses etc and make it look cleaner. I have a tophat intake plenum, so no crossover the valve cover, and I'd like to keep it free.
heres a picture of one of the oil breather? lines. Its a one way check valve? not sure if thats what its called, but i blew on it and it only goes away from the valve cover toward the intake plenum (stock one). My question is, on the rb25, theres a number of oil breathers including this one, which ones are ok to reroute? I plugged my intake hose going to the turbo, and am gonna run one of those breather filters to the drivers side oil thingy (the one that "t"s on the valve cover. Im going to leave the line that goes across the drivers side to the passenger side. I was hoping to put the one thats on the side of the valvecover (not top) to the hose which connects under the intake plenum (the one with the one way check valve pictured below)
