HxC_Nismo »
https://forums.nicoclub.com/hxc-nismo-u47634.html
Mon Feb 09, 2015 8:55 pm
well since your venting the other part of the catch can, your putting a pressure on your crankcase instead of maintaining a vacuum on the crankcase. I would run the other part of the catch can and plumb it back into the air intake on your turbo so you can maintain a vacuum on the crankcase under boost so your oil rings can do its job by preventing blow by. Your pcv valve keeps a vacuum on the crankcase when your sitting at an idle and when you are under boost the pcv closes and the other port on the valve cover is suppose to go to the air intake on the turbo because that is the only vacuum source when your under boost since the turbo is sucking air in when accelerating. so get rid of the vent and run a hose from your catch can to your air intake and as long as your piston rings are not damaged that should fix that problem.
