+1SVTCOBRA wrote:http://forums.g35club.org/zerothread/355022
Do you have ANY warranty left?? Powertrain or extended??
From what I hear the only fix is to replace the valve cover.
I don't know if it will eventually cause problems, but mine didn't while I had it. I traded it in on a coupe before getting it fixed.
I haven't personally worked on the VQ yet but with most cars replacing a valve cover isn't that hard. If you have a socket set you pretty much can get it done in less than 2 hours.msforever wrote:Hey guys, while replacing my plugs yesterday on my 2003 G35, I found pretty much oil around the last two plugs. (Closest to the windshield) Both upon and under the plugs, but the other 4 are very clean.
I have no idea where is the oil come from. The car runs fine with no problems, and there is no warning light on. What do you guys think? I will check it later and see if there is oil again. Really wanna know if that could be big problem, thanks!
I am assuming the mileage is 105k and not 10500.With 105k miles and leaking valve covers I don't think this qualifies for a recall or it is Nissan's fault if the vehicle has not had regular service.When you purchase a six almost 7 year old vehicle the advantage for you is you save much of the initial depreciation that occurs on any new vehicle.On the other hand you need to set aside a reserve to cover unforseen maintenance issues. When you purchase a used vehicle from a dealer youwill pay a little more but usually with some sort of warranty on a certified used car. Purchase from a private owner and you save some money but your purchase is as is.msforever wrote:Thanks guys! Unfortunately I don't have any warranty left. I bought the car about 2 months ago, with 10500 miles on it. I just find it looks like a common problem for the Nissan 3.5 engine, how could Nissan just let it be but don't recall some cars! .
Check the FSM for your car.http://www.nicoclub.com/FSM/G35/Joey666Crack wrote:
Yes you are right it is 105K sorry for my mistake, and I totally understand that the risk of buying an used car, and I would like to take it of course. By the way the car has been maintaining by the dealership all the time, and just done the 90K maintenance over there last year, a book of record in hand and that's one of the reason of buying it. I am just saying that if the problem is not uncommon and have been bothering so many owners, Nissan at least should do something such like producing some reliable valve covers for us to purchase.telcoman wrote:
Telcoman
