oil and water temp install questions help please
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
Can someone please tell me a way to install these gauges???? Its been killin me. Do they make an adapter or what b/c I dont have a clue how to keep them from leaking. Notice on both the oil and the water temp, the screw in part is seperate from the sensor and any forward pressure on the line would cause the sensor to go deeper into the pan (oil) or radiator (water). Both gauges are nismo, so does nismo make an adapter for the sr motor......they came off an s14 in Japan. Here are the pics to show what Im talking about.
Water temp. sensor and screw togetherwater temp and screw apart
oil temp sensor and screw togetheroil temp sensor and screw apart
Thanks very much in advance. I need help really bad b/c Im relocating my a/c controls to my console to install the gauges in place of it.
Modified by D1 guy at 9:03 AM 8/26/2005
D1 guy
bump ahhhh
