c-rad »
https://forums.nicoclub.com/c-rad-u19918.html
Wed Sep 21, 2005 10:08 am
Ok, I always see the Taka braided turbo lines for the SR. Now, I am 99% sure that the lines are the same for the CA, SR, and all the GT T2 CHRA's. Is that correct? Reason I am asking is, I am going to make all these lines for my motor, and just need to make sure all the fittings are available. $170 is ridiculous for those lines. I can make each line at my local 'performance' shop for around $20 each.
EDIT: I am guessing -4 would be a good size for the oil feed and -6 for the water lines? The banjo bolt on the coolant return is 12x1.5, right? And the oil feed fitting at the block is 10x1.25? Now I just need to thread specs on the CHRA fittings.
Modified by c-rad at 5:08 PM 9/21/2005
