Well, a compression test was done 2 weeks ago: 149x5, and 140x1. They just called about 30 minutes ago and said that a spark plug was wet with gas and that adjacent o-ring was messed up. Replaced, and hardly any smoke anymore and for some reason the oil is just burning off and isn't leaking anymore....fast_s14 wrote:my buddies car did the same thing awhile back. He replaced the turbo and still had bad smoke like yours.. Did compression chek and found number 6 with no compression. tore it apart and found the piston ring lands were melted. So check your compression before purchasing a new turbo.
Is that the cold piping side or the hot piping side?SullivanRacing06 wrote:check the charge pipe see if there ne oil in there,
Neejay wrote:The messed up o-ring really was the cause of all the extra smoke. Reporting back to say that it only smokes now when I get on it then come to a complete stop AND while I'm really getting on it. Driving regularly, it doesn't smoke. Still sounds like the turbo? Not a valve guide/stem?
EDIT: It also doesn't leak oil anymore.
Yeah, when it was my o-ring, it caused a grey smoke. Now it's A LOT less and blue. Last night I found a vacuum leak which was the pcv hose's port on the intake manifold. The guy who did my swap said he meant to tell me that when he started the swap and that I can bring it by there and he'd replace it/fix it.dftsilvia wrote:u sure thats oil leaking and not gas? i had a bad injector o-ring on my ka n it was dumping so much fuel it was squirting out between the head n exh. mani.
sounds like u got it fixed tho.
off topic a lil, but is that the 200 dollar syko elbow?
Im hoping that was the source of my smoke. I just took the intake off and there was NO oil or oil residue in the compressor wheels, with almost no shaft play in and out and very little side to side. Blades also look good. I temporarily hammered the port back in, and it was snug, then I put some silicone around it. I just need it to hold so I can drive it to the shop and have them weld or epoxy the port permanently.dftsilvia wrote:yeah it will deff smoke if you crankcase is getting pressurized from a faulty pcv
good deal on the elbow. i just used a stock elbow with a r32 greddy dp.
Yep, stock turbo.l0nestar wrote:#2 & 4 plugs -- EEK! Stock turbo?
Killswitch. Decker is great! (mainly dealt with him during my swap) I had them troubleshoot and figure out that the injectors were the problem. I just couldn't afford to keep it there for anymore troubleshooting. Hence, this thread. lollazyboi444 wrote:Neejay. What shop did your swap? Also where did you get your turbo outlet pipe from?
I did, originally, when I was going to be the one doing the swap. lol My Nismo mounts have less than 1k miles on them. I bought em new and used them on my KA. I still have the R33 crossmember.lazyboi444 wrote:I guess. Why didn't you go with using the R33 crossmember? With new Nismo mounts? Glad i have a garage lol.
