qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Wed Sep 17, 2008 4:53 pm
Ok, here are the OIL ANALYSIS latest results from Blackstone Labs.
Redline oil 1/2 10w-30 and 1/2 10w-40 mixture to yield a 10w-35 weight for summer driving. Oil was in use for 120 days and 4511 miles, and odometer read 216,542 at the time of sample and change on 8/24/08. Blackstones comment is wear looks admirable in this sample
Wear metals found in parts per million {PPM}Aluminum 0chrome 0iron 13copper 1lead 7tin 1
Additives in parts per million {PPM}
Good Goly miss molly {molybdenum} 731 nickel 1manganese 0silver 0titanium 0potassium 2boron 19silicon {used as an additive and DIRT} 11sodium 17calcium 2694magnesium 9phosporus 1046 zinc 1245 barium 0
Vicosity at 100 degrees C 12.7flashpoint 405 degrees F.fuel Less than 0.5%antifreeze 0.0water 0.0insolubles 0.3%
Here is where the experiment part comes in....I have always used the Infiniti 15208-60u00 oil filter, changed at each oil change interval, including for the above oil run. I changed the oil and again installed Redline but have switched to the new fancy Amsoil EAO38 synteq all synthetic element filter so raved about on another site, supposidly the finest filter on the market, and good for 25,000 miles or one year, bla bla bla- you know the Amsoil hype!
Well I plan on running this new oil/filter for the same 4500 miles, drainig the oil and catching a sample and seeing if there is any measurable decrease in wear particles attributed to the filter....then refill with new redline oil running another 4500 miles ON THE SAME USED FILTER and testing again.
Will the amsoil filter work better as the miles add up on it and it develops a cake of debris causing finer and finer filteration, or will it become clogged in 9000 miles, go into bypass and show MORE wear....we will find out
