REDDOG »
https://forums.nicoclub.com/reddog-u85340.html
Mon Feb 18, 2008 1:26 am
On second thought I had some time now and thought I'd start in on what the numbers mean.
$.25 Oil Analysis 101
FE= Iron-Wear metal from Piston rings, rods, cams, etc. Traces can be found in new oils from piping, storage tanks, etc.
Cr= Chromium-from piston rings
Pb=Lead- bearings, can also be in some gasoline additives
CU= Copper- Bushings, bearings, oil coolers, anti seize compound
Sn= Tin= Bearings
Al= Aluminum-bearings, pistons
Ni= Nickel- Stainless steel, such as valves. Important indicator for dirt ingestion by the intake, as valves get "sandblasted".
AG=Silver- Don't see this much, but they test for it.
Si=Silicon- "Dirt" The high silicon from my post above is from the newness of the engine. Silicon leaches out of seals/sealants and into the oil. This should trend down fairly sharply in the next few oil changes. High silicon can also indicate dirt getting into the engine, either through the intake, or by other means.
B= Boron- Oil additive Anti wear/antioxidant. Can also be found in coolant.
Na= Sodium- Classic coolant additive. Normal for a very small amount to make it through the air filter, especially if winter driving is an issue. Increasingly common in oils as an antiwear/anti corrosion additive.
Mg and Ca= Magnesium and Calcium-Oil Additives Metalllic detergents/dispersants, keep contaminants in suspension and keep your engine clean. Also add alkalinity(sp.?) to oil to neutralize acids created by combustion byproducts and condensation/moisture. See TBN below.
P and Z= Phosphorus and Zinc- Antiwear additives/antioxidants
Mo= Molybdenum-Antiwear additive/friction modifier/antioxidant in oils.
K= Potassium, coolant additive.
Fuel= Amount of fuel in oil, by %. The less the better but most consider 2% the upper limit. Causes include short trip driving in cold weather, poor engine tune, leaky injectors, etc.
Visc. @ 100 C= Viscosity at 100 degrees Celcius (212 F) , in Centistokes. The oil's "thickness" or resistance to flow. The viscosity above was low, in the 20 weight range. Judging by smell I think some of that had to do with fuel dilution, despite what the lab report says. Some viscosity loss is also caused by shearing, or the oil getting mechanically broken into smaller pieces by the engine.
H2O= Water, %. Don't want water in your oil! From short trip driving , poor PCV performance, excessive blowby.
Solids=Soot, insoluables.
Coolant/Glycol= Presence of antifreeze in oil-not a good thing. Usually a positive/negative test.
TBN= Total Base Number- measure of the reserve alkalinity of an oil, aka it's remaining ability to neutralize acids caused by moisture and combustion byproducts. Acids can corrode/wear an engine while it sits in your driveway, and also has a negative impact on cleanliness.
Oxid and Nitr=Oxidation and Nitration= Oxidation is the reaction of the oil with oxygen that causes oil thickening and acidity. Nitration is related to sludge formation.
Modified by REDDOG at 3:38 AM 2/18/2008
