Jesda »
https://forums.nicoclub.com/jesda-u7038.html
Thu Jan 06, 2005 10:04 pm
OH THANK GOODNESS I'M DONE.
Pics:
I attempted to super glue a socket to the screw, so I could get a grip on it and loosen it, but the glue didnt hold. And I forgot to buy an impact screwdriver. Oh well.
The injector on the right wasnt too bad. I used the closed end of a wrench to wrap around the screw, hammered on it with the back of a screwdriver, then turned it loose.
An injector Evan sent.
Another injector. Greased it up, put new o-rings on, and put it straight in without drama.
The last injector was nearly impossible. The screw on the left was difficult to get at, so I shoved a flathead under the right and pried up, breaking off a piece. Then I was able to turn the other side loose and remove the injector.
Removed!
I went for a drive, and it was like a new car. I came to a stop at the end of an onramp and thought it died, so I went to crank it and of course it was still running. Its never been this smooth since I've owned it. Additionally, I was able to readjust the AAC (aka IAC) to two turns out so the idle is normal now. There's one more injector in the back that needs to be replaced -- that can wait.
HUGE THANKS to Evan for sending me the injectors! Saved me a tremendous amount of money and trouble. I owe you!
-Jesda
