Ohm law? resistors...
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
ok ok ok i know ive had numerous questions about this in the past...
Tomorrow begins my first lighting install in my friends xB..
I understand now (thru docs help) most of the process... but what im concerned with is resistors of some sort...
I have a bunch of leds, cold cathodes, and other lights i will be connecting directly to the battery... i will have the appropriate inline mini-fuse and switch connected...
What else needs to be in the mix... is a resistor/regulator required... does this OHM rule mean anything?
08Coupe
Car: 2008 Altima Coupe
Watts/volts= AmpsorAmps X Volts= watts
PS. If the wires get hot or smoke you did something wrong
vballer22
Car: 2008 altima coupe 2.5s
Ohms law doesnt really apply here. audio setups as you know run between 2-4 ohms, but lights and leds and stuff like that actually have a resistance of more like 75 ohms or so. even though lower ohms equal more power, higher ohms are cleaner and more efficient, and most importantly run much cooler. thats why many jl audio subs run 8 ohms, it stays cool and has clean power. it takes more power to power an 8 ohm sub, but if you run jl you can probably afford it. Haha so in short dont wory about ohms law.
with the fuse in line you should be totally fine.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Yea, ohms change with lighting depending on temperature. Operating resistance is different than cold resistance. Please for God Sakes, DO NOT USE A MULTIMETER TO MEASURE FROM THE BATTERY 12V SOURCE AND ACCIDENTLY HIT A GROUND. You will blow you meter. Or if the fuse fails you will spot weld your meter leads to the respective sources and your battery WILL explode. Bad times
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
adidas2go wrote:Please for God Sakes, DO NOT USE A MULTIMETER TO MEASURE FROM THE BATTERY 12V SOURCE AND ACCIDENTLY HIT A GROUND. You will blow you meter. Or if the fuse fails you will spot weld your meter leads to the respective sources and your battery WILL explode. Bad times
That actually sounds cool. Wouldn't want to do it though. Thanks for the tip Blake!
