rookie92 »
https://forums.nicoclub.com/rookie92-u55525.html
Mon Mar 22, 2010 7:26 am
GOLDEN, i figured it wasn't there. (I mentioned in another thread that i spayed pb blaster all over the inside of my door. Do you think i shorted the window motor? If not should i replace the switch and hope for the best?)
As far as the caliper it's not metal to metal...but very little of my pad is left. So you think it's probably a stuck caliper pin? Last time that happened to my miata it was a PAIN to fix, yes fix not replace. Should i look into some sort of rear caliper upgrade? if so what am i looking for?
Modified by rookie92 at 10:31 AM 3/22/2010
