Hey Speedracer,I had the machine shop clean the head, check if it's level and cut it, replace the seals, replace the valve springs (to Greddy), grind off the old gaskets, and polish the intake side. I had the work done by Gosney's Auto down here in Auburn. I am not registered with NWN, but I do search on there once in a while. Gettin real excited about the swap, my car has been down for almost 2 years (almost since the 2001 HIN, that's the pic in my sig...
) Are you part of any crew up here? Maybe you've seen my car before because I used to work at Ultraspeed back in the day ('98-'00 before the new owners that did the major drug smuggling) and then did some shows with Garage SPL (Same guys I worked for at Ultraspeed). Anyways, thanks for the interest!!
