Oh, Those of great knowledge...HELP!!!
[DTH]240sx
Alrighty, here goes, i ruined yet another 1993 240sx auto transmission. and i figured i'd just buy a motor and transmission and swap the pair just for the fun of it. but now i've got a problem. the wiring for the fuse box on the passenger side of the car to the starter OR the nuetral safety switch is messed up. all i need is that wiring diagram, or if someone with a similar solution. well, let me break it down for you...which plug goes into the plug right under the fuse box on that passenger side, the one from the transmission or the one that looks exactly like it coming from somewhere else???? everything else is done, it took me 2 and a half days for the entire thing, so im kinda mad cuz im without transportation until i can get either a wiring diagram or a solution. thanks a lot guys, long time listener, first time caller....err...messager, rather.
NISTECH
well we appriciate you listening err...reading.
The connectors should match by color. for example if you have a brown connector it goes into the brown connector. the only reason this wouldnt work is if you are dealing with 2 different cars wiring systems. you have a good day sir!
