bentvalves »
https://forums.nicoclub.com/bentvalves-u46428.html
Fri Oct 30, 2009 9:59 am
so, I decided to swap back to the stock cast iron turbo manifold on my setup. I like that 1/4 and 2/3 runners are paired, and therefore energy at turbine wheel per engine revolution theoretically should be greater.
Im using the same turbo as before, 2871R / 63hotside / 3" inlet. With the XS power tubular manifold I could hold actuator pressure to 25 psi no overboosting issues. Now with the stock turbo manifold, Im having issues where I absolutly cannot control boost. To simplify diagnosing the problem, I physically removed the actuator arm off the wastegate flapper and it still makes 25+ psi slowy no problem but directly related to engine RPM.
I have a few options, both of which I think will get me nowhere.
-I have an 86 hotside kicking around....I could install that, but I think its just going to take longer to overboost
-Port the hole in the turbine housing as big as I can go with a fair amount of overlap still being provided by the flapper.
what I am thinking of doing is installing ca18de camshafts or ca18det cams to bump VE down a bit. Right now I have tomei 256 cams in the head. Theoretically they are going to provide the turbine with more energy.
anybody using a stock cast iron turbo manifold with an upgraded turbocharger pleasse chime in.
