jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Fri Jan 19, 2007 7:52 am
well if this is something intermittent, i suggest taking a look at the vacuum modultor and governor on the transmission. check for any ruptures in the lines, even hairline cracks.
if you cant find it there, if you have a vacuum pump you can apply vacuum to modulator and governor and see if it shifts into the gears.
if still no success, maybe its the TCM after all.
