Dongoesby »
https://forums.nicoclub.com/dongoesby-u44963.html
Fri Apr 13, 2007 6:52 pm
So I found there is noise coming from the back of my 98' 240sx 5spd, and I took it to a shop since it is getting louder everytime I turn in a low speed. The mechanic used a tool like what the doctor uses to listen how the rear wheels run. After he found nothing wrong with the axels, control arms and other suspension parts, he suggested the gear box might be the problem. And I asked: "Isn't the gear box, so called transmission, located in the front right under the shifter?" (wtf?) He said something like the gear box is in the rear while pointing at where the LSD is located.... Maybe he thinks I'm not knowledgable about cars, but I think he knows less about my car than I do.
After that, I told him that the car is equiped with am aftermarket 1.5 lsd, and it might be low on fluid, so maybe that is problem because the noises only come out when the car turns. He still insists that the car has no lsd, but after couple simple tests, he found out the lsd is not installed with a complete housing, instead, just the gears inside. (which also surprises me too). The mechanic said the lsd is not installed properly, because, first, it wasn't swapped with the complete housing which would required more skill to fit the gears in the housing, second, the noises from the rear are maybe the evidence that shows the gears in the LSD aren't installed precisely.
Finally, after my suggestions to him that it is not the gear box and we should put oil in the lsd to test it out, and it turns out the noises are minimized! However, the noise still exists but just not as noticable. And then he charged me 75$ for hourly labor...
Here are my questions: Are the gears in my LSD already worn out? Is it too late to open it up again and adjust it? (how much will it cost?) Or if I leave it be, and the gears will fit themselves perfectly by a little bit of time to break in? (as the previous owner told me that he just got it installed by a reputable shop)
Modified by Dongoesby at 10:19 PM 4/13/2007
