DriftingisLame »
https://forums.nicoclub.com/driftingislame-u25409.html
Fri Oct 26, 2007 5:25 pm
I was at the dragstrip for the first time with my new motor about 3 weeks ago. It had been pulling very well at 14 psi, for a few months, consistant 12:1 A/F ratio. I knew something was wrong when my trap speed was only 1 mph faster than on my stock turbo at 12 psi. I didnt notice when it stopped pulling hard, it may have been 3rd-4th gear, as 1st and 2nd felt like a cheetah on crack! I ran once more time and then parked it, as I had developed a misfire. I checked for codes and found a knock code. It had a loud tap every time it would misfire, sounded mechanical, coming from the head.
I figured this tap could be some sort of stuck lifter, or something having to do with the lifters, hanging a valve open slightly, causing no compression, and a misfire. I removed the lifters and had them rebuilt, as it was a good idea anyway (they're super quiet now!).
Blah blah blah... Long story short, The car developed a bit of a very random smoke, blue, like burning oil, out the exhaust. I fixed the misfire until it got a little hot again, I swapped coil packs, spark plugs, checked injectors, and all connections. I went to get on it, as I thought I had fixed the misfire, and the car started smoking again, and missing. I pulled into my buddy's garage and parked it, smoking, tired and pissed off, I went in and had myself a nap. I came back to a big puddle of oil (coming from the PCV). And there it stays...
I havent moved it since then, Havent had much time to work on it. I did however get to comp testing cyl 1-4. 135, 135, 140, 135, ***, ***.
I could have sworn my misfire was on cylinder #1, so I thought that would read low compression, perhaps a broken ring land. I'm rather suprised the compression numbers are even thus far.
I really didnt need this right now..
Any constructive comments appeciated, should be getting to cyl's 5-6 by tomorrow.
Thanks...-Max
