Oh NO....Another timing Question.....after ecu swap.
blues14
Car: 1995 Nissan 240SX GTS-t
I recently had my timing set to 15 degrees on my rb20det with manual transmission and Auto Ecu . Now, I just put in an actual manual transmission ecu and the car drives smoother at under 4K rpm, but has no power above 4k rpm. Do i need to have my timing re-set again? or could there be some other cause? i had this problem with my car on the auto ecu before i took it in to get the timing set, and now its back.
goofynick6
Car: 1995 S14.5 RB20DET
Is the neutral switch hooked up? If not it throws off timing, needs to be used.
blues14
how exactly would i check for that?
blues14
forgot to mention my rb was originally installed as an automatic and has been converted to 5-speed. maybe i will switch back to auto ecu.,,,,if i switch back to auto ecu, should i advance my timing a little?
