H8tred »
https://forums.nicoclub.com/h8tred-u42261.html
Wed Aug 16, 2006 9:24 am
OBX High Power Performance Spark Plug Wires are the "highest quality" (Remains to be seen) and thickest wires available in today's market. Aerospace silicone outer layer, which protects OBX wires, is able to withstand 600 degrees of extreme engine temperature during competition or daily driving (Big whoop, all silicone jacketed wires can make this claim.). 10.3mm, 6 individually wrapped 18 strand copper core are used to ignite the high combustion process (This is part of the question, I think copper core wires degrade faster). OBX wires enhances maximum combustion and is compatitble with all types and brands of spark plugs. Increase tremendous voltage output for high performance compact engines. Use in conjunction with high power firing spark plugs for maximum horsepower gain. Dyno tested and proven. Increase 5-7 horsepower and greater fuel and engine efficiency at low-end as well as top speed.
Key Features:
10.3mm heavy-duty quality construction 100% silicone double wrap (Sounds good)
6 individually wrapped 18 strand copper core(Copper degrades fairly fast, but their is 6 haha)
Instantaneous maximum combustion(Um... Yeah, most wires do that...)
Dyno tested to improve 15% horsepower than stock wires(Well, they just said 5-7 Hp, a 15% gain over stock would be 23.25 Hp. Seems like someone needs to learn English and math...)
Low resistant(Again with the English)
Fits: All 1991-1998 Nissan 240SX 2.4L all model(Shouldn't that be 89-94? I mean, I guess they could just include the coil wire with all packages, but why pay more if you don't need it?)
Package Included:
Set includes 4 spark plug wires. Brand new in retail box by OBX(Shouldn't that be 5?)
I'm going to stick with the NGK wires from Sparkplugs.com. I checked into OEM Nissan wires, but I'm not willing to pay $89+ for wires when I feel that the NGKs are just as good if not better. The OBX look good at first glance, but I'm sure they'll need replacing after 6,000-8,000 miles of normal driving. The ones I have now were on the car when I bought it, but I checked them, and the resistance goes from 80 ohms on the coil wire up to 126 ohms on the 4th cylinder. The FSM says anything up to 30 ohms is spec.
