krimson_viper »
https://forums.nicoclub.com/krimson-viper-u278997.html
Wed Nov 29, 2017 6:17 pm
I’m not sure how much the car shares with the MS3, but if the mounts are the same, JBR and Damond make great ones and gives a package deal. You’ll gain a lot of NVH as a result, but they supposedly die out. JBR I believe barely does, along with TRZ ones. I bring that up because the rear motor mount in my car was the source of a lot of torque steer, as well as a lot of failures for all 3 stock mounts being a regular thing. After upgrading my rear motor mount (RMM), a lot of it disappeared. I don’t beat on my car like a lot do and at 80k miles I see no signs of needing to upgrade the other two. Hopefully I’ll never have to.
I read into the car a little bit and I saw the stock turbo can handle 400hp and people regularly get around there with bolt ons and a tune for e85. Of course, you gotta research it yourself to verify. I was just skimming. Very strong power plant. The MS3 uses the K04 turbo and that starts to crap out at around 300hp. If I research more, I will go with a BNR S3 when my turbo finally kicks rocks. If I can get away with it of course. I have to wrestle with CARB and the TIP needs to be slightly larger to fit onto the S3. If not, I’ll go with an S1 instead. I could go S2, but that’s just a poor choice for spending cash.
Oh. Invest in walnut blasting and getting to know your intake valves. If you’re direct injection, you’ll be removing carbon around every 20-30k miles. I need to do mine, but I’m scared lol. Oh, and broke. Being a college student, I barely have enough cash to breathe.
