Oh gawd more fan questions
iHEARTcivics
Car: white 1989 240SX Hatch
I need an electric fan, how many CFM does the stock crank powered fan produce? Would one 16" electric fan work if it produced 2500CFM?
TheOne
Car: 93 240sx FB
stock crank fan does 3000somefin cfm @ 3k rpm(when engaged)
supposely 1800cfm is enough to cool for daily driving, but you'd want more, also i don't know if a 16" fan fits the stock rad and you may want to cover as much as you can.
neverlift
you need more than 1800 for dd if your in warm weather area. I know from past errors. I would say to get a 2 14's or a 16 and 14. Even two 12 or 10 would probably work. Just need to cover plenty of area. You could put 3 16" fans and it would not out flow the mechanical fan at 4k. At idle it moves over 2000 cfm.
nismo_power
Car: 91 240sx fastback se
the stock electric fan is good enough for dd..just wire it up to a switch and get rid of the clutch fan...its strong enough to cool the radiator down...with no problems...
Shift_Kouki
Car: 95 Nissan 240SX SE
nismo_power wrote:the stock electric fan is good enough for dd..just wire it up to a switch and get rid of the clutch fan...its strong enough to cool the radiator down...with no problems...
Are you speaking of the electric altima fans that were used in the transverse mounting the same engine?? I would think those are the cheapest and safest electrical fans out there... as they were already sized / picked for the same engine.
TheOne
Car: 93 240sx FB
no he's talkin about the A/C fan that comes stock with a 240sx.(with a/c of course!)
nismo_power
exactly what im taking about...the a/c fan is good enough to kool down the car....u dont need to spend all that money for a expensive fan when there is already one on ur car and all u need to do is wire it up!!!!!for daily driving it is good but but for other things???
neverlift
I will only say that I live in florida and that the ac fan and 14" wont cut it, but the mechanical will.
nismo_power
hmmmm...i live in the desert and it works great for me dd....so i cant see why it wouldnt work???
pr240sx
Get Altima fanswhen wired correctly will cool down your car perfectlyEven in the caribbean tropic, turbo engine and AC cold!Be sure to raise the base idle just a tad to compensate the electrical load.
