1. The motor was rebuilt due to broken timing belt....after the rebuild the idler pulleys and autotensioner have not been replaced. The car has 176,000 on it and i dont really want to spend 300 bucks for those parts (i can if i have to though)....but moreover im nervous about f*** up the timing belt and causing the valves to bend on start. WHAT TO DO?? I drive it less than 20 miles a week if that....sometimes only 20 a month. Save up and have them done with timing belt job when i have more money (just finished college)?....none of the pulleys are making noise, but i cant test to see if they spin freely to know if replacement is necessary without removing the timing belt.
2. Replacing the VTC Springs....is it just as easy as removing the plate off the cam gears and putting a new one it....and do i NEED a new seal?
3. Replacing the hard silverish coolant pipes to the motor...do i need to make a seal with permatex blue....they didnt have any sealant on them upon removal.
4. What is good to clean the motor with out messing up the paint...everything i find is corrosive to paint.
Help with any...or ALL of these would be much appreciated. By the way its a NA and my experience level is....ummm... plenum pull/injector replacment/bose delete/etc. So i have some know how, but im not too much of a gear head, I prefer the interior. Hence why the timing belt is a big deal....something so cheap could ruin the car...again (like when i bought it). I am nervous, im sure you all know that feeling in your stomachs....and i need yalls help and support. Thanks in advance.
Thanks....im really...well upset about all this, because although the timing belt is exposed, i dont know if i trust myself to f*** with it.
