Offset ?
nismostreetracer
Car: Cars, Sports (Go Bucs!!!)
I just purchased a set of rims for my 1995 240SX SE. The question I had is will these wheels rub with a 43+ offset? They are ADR's with a split five design. :D
Exar-Kun
Car: 2005 350Z
will it rain 6 years from now?
...what size are the rims! just telling us the offset doesnt mean jack man. help us help you..:)-chetwe need the diameter and width of the wheel, and tire size you plan on running to help.
nismostreetracer
The guy I brought them from says they will fit. :yesnod
nismostreetracer
BTW they are 17x7's. I'll probably use 205/40/17 or 215/40/17 tires.
Exar-Kun
Car: 2005 350Z
yes they will fit, but might require a small(5mm) spacer to clear coilovers.-chet
nismostreetracer
Would I need spacers on all 4 sides or just in the rear?
Exar-Kun
Car: 2005 350Z
probably just the front, but I would put them on all 4 corners just to be safe. if you dont use coilovers, I wouldnt worry about it.-chet
nismostreetracer
I don't plan on putting coilovers on yet however that will be a future project once I get some more green. Thanks!
91nis240
no w/ 205 tires they will be fine, w/ 215 tires they may still work (spacers may be needed) Now if you got coil overs you will have no fitting problems what so ever.
Structure240sx
i wouldnt go with the 205's tho jsut cuz the sidewall is so small i wont look right on a 240. i have a 95 too you would have to lower it too much
nismostreetracer
205 is width of the tire not the thickness. Density (thickness) would be 50,45,40,35,etc........
Exar-Kun
Car: 2005 350Z
no. you're wrong. read the FAQ article again. those numbers(50, 45, etc) are called an 'aspect ratio'. it means that the sidewall height is X percent of the tire width( the 205) from the widest points.
example:225-45-17
is 225mm from sidewall to sidewall(across the tire)is (225mm*.45=) 101mm high sidewallon a 17 inch diameter wheel.
get it?-chet
nismostreetracer
I know that but what the other guy said was referring to was how high the tire sidewall will be. I've already been told a 205/40/17 tire will fit.
