Hi guys, pickup this set of 18s" look like those on member 240RB1, Eric's white Q looking really nice.
http://www.ebay.com/itm/271139432917?ss ... 1497.l2649
After putting the numbers together and I am now a little nervous on the fitment. Not planing to lower as everything stays.
The spec in the manual for the OE rims: 15 X 6.5, 5x114.3 mm, 45 mm offset all around, ? ok with ruler
The spec for the z rims:................... 18 x 8 , 5x114.3 mm, 30 mm offset all around, 66.1 mm hub bore
The differential, if I am not wrong, is 0.5(8-6.5)in + (45-30)mm = 1.34 in or 34 mm further out. Is it too much?
I am looking at 3 options of tires size: 245/40-18, 235/45-18 and 225/45-18.
Now, should I be nervous? would it work? plug and play? or looking at some sort of mods?
Your knowledge and wisdom is greatly appreciated.
