offset questions
cheez80
Car: percussion =D
hey guys
just wondering if 17x7 ssr integrals offset 40 will fit on s13?
used search already, could somebody tell me?
SmithSR
Car: 240sx
It certainly should. The factory offset is +40, with a 6" width(unless I'm losing my mind and thinking about older women again..?). Check for suspension clearance! Always always test fit the exact wheel you are buying before handing over any money, and be sure to have suspension work done before you buy wheels.... you must properly fit wheels to the car, don't fit the car to your wheels. It's easier to pick a different wheel that will fit better, it's harder to modify suspension to allow clearance of a must-have wheel.
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
The vehicle specific Integral SSR used to make in a 17X7 was an ET38. 40 should be no problem (close enough for me). Just make sure you have the correct 66mm center ring.
cheez80
Car: percussion =D
thanks guys :)
