Offset questions 17 by 9 and 17 by 8 with +35 offset
Rican_Nick
i know i know.. these offset questions are asked ALL the time.. i searched around on a few forums to see if i can get pics of a s13 with wheels this size/offset 17 by 9 and 17 by 8 with +35 offset.. i know that offset is not that aggressive jsut wondering if it will clear coilovers and z brakes all around?? will i need to roll if dumped i think i would slightly.
i am thinkin rear will be fine and front need a 10mm spacer?? can anyone confirm.. or have pics of these sizes/offsets on there car.
thanks in advance.
240sxjeff
Car: nissan 240sx zenki version
You would most likely have to roll your fenders and the front I'm pretty sure you need spacers in the front.There is a guy on here with a green s13 hatch that has wheels with somewhat of those specs.Search for it in this forum (tires,wheels, brakes...) there is like 2 pages on it
Rican_Nick
240sxjeff wrote:You would most likely have to roll your fenders and the front I'm pretty sure you need spacers in the front.There is a guy on here with a green s13 hatch that has wheels with somewhat of those specs.Search for it in this forum (tires,wheels, brakes...) there is like 2 pages on it
thanks i'll be lookin for it.
raging panda
Car: s13 coupe
word on the street is your 9 inch wheels with a 35 offset will rub if you have coilovers, thats only what ive heard, i dont know from experience, but i think it was anything over a +30 or so on a 9 inch will rub suspension.
edit: oops, i meant on front only, rear should be fine, i think your setup should work out
Rican_Nick
raging panda wrote:word on the street is your 9 inch wheels with a 35 offset will rub if you have coilovers, thats only what ive heard, i dont know from experience, but i think it was anything over a +30 or so on a 9 inch will rub suspension.
yea x 9's would def rub up front.. this set up is goin to work.. just not as aggressive as i would of liked..
but damn type c's are light as **** i'll post pics after i get them powder coated.
chmercer
remove the bn sports car from your sig if you are going to run weakass rims like that.
Exar-Kun
Car: 2005 350Z
that car is fugly anyway.
Get some good, light 17x8 +22 all around, 225-45-17 and call it a day. YOu have a fairly neutral car, why compromise it by exagerating the understeer?.....
That said, this has been discussed quite a bit, in finium to be exact. Low down:
you'll probably need spacers on the front, epending on tire size and coilover/suspension setup...it'll be very close..rear should be ok.
Locking due to fairness.
-Chet
