Offset question
S14Dorikin
Car: '92 240 coupe
*Moved from 240SX forum*
Yes, I searched. Just need a plain simple answer. Will they fit, clear coilovers, brakes, and do I need to do any modifications such as fender rolling or wide fenders.
1993 240SX Hatch300ZX front calipersCoilovers all around
This is the size I'm looking at:Advan SA3 18x8.5+35 18x9.5+42
And any pics of a 240 with a similar setup are much appreciated!
Modified by S14Dorikin at 11:30 PM 11/14/2006
hannibal
Car: Red Line to Glenmont
I believe the fronts will hit the struts. x8 +35 comes very close and youre trying to add an 1/4" to the inside. And the offset of the rears leaves a little to be desired. I dont think you'd have to roll the rears with that offset. Something around +20 would look better IMO.
These are from RB Motoring arent they? Just keep looking around for a better set. Try Takumi Project. They have some SA3's, but none in 18"http://www.takumiproject.com/brand.asp?brand=ADVAN
S14Dorikin
Car: '92 240 coupe
Really? Even if I used spacers?
Yeap RBmotoring...I know I look around on each site from time to time to see what they have. Thanks for the info.
S14Dorikin
Car: '92 240 coupe
Ok, let me ask this then. What is the usual offset ppl use to get it flush to the fenders without coilover problems and no rubbing?
hannibal
This was recommended by a member named Orion (Brian) for an S13:
For a decent look, and easy fitment:
7.5", +10
8", +15
8.5", +20
9", +25
Its just a guide though. In your case, I'd do 8.5" +20-25 in the front and 9.5 +30ish in the rear. Now that I type this, a 10mm spacer in front and a 5-10 spacer in the rear should look pretty good. But I'd rather have the offset and lip built into the wheel.
BTW, I think the 18" Sportmax 962 you see a lot come in 9.5" +38mm so if you see a pic of those, you can compare.
And heres a good calculator. You can use 8" +35 as the closest clearance to the strut the S13 can take and just plug in numbers of the wheels youre considering. I know the rear has more room, but I dont know how much. I'd use 9" +20 as starting point for the rear.http://www.1010tires.com/WheelOffsetCalculator.asp
Heres 17x9 +20 F/R for comparison.http://www.splparts.com/Parts/...G.htm
S14Dorikin
Car: '92 240 coupe
Much thanks for that.
