Juujai »
https://forums.nicoclub.com/juujai-u19527.html
Fri Mar 03, 2006 2:23 pm
it'll fit with camber adjustments. it's a slightly aggressive fit so think 2-3degrees negative camber and stretched tires.
you could fit anything if you dial in the camber to adjust to it. lower offset = more camber that's how it works.
but to just slap it on it'll fit fine just stick out about an inch or so.
