offset help!!
TypeX4Sho
Car: 91 Sil40 96 zenki
i want to run 18x9-10 in the rear and 18x 8.5 up front what kind of offsets would i need for regular s13 bodyalso what would i go with if i wanted to do maybe like a widebody 30mm in the back and 20 mm in the front for them to look good what would be that offset thanks a lot
adrianfromthecastle
Car: 1992 Nissan 240sx
TypeX4Sho wrote:i want to run 18x9-10 in the rear and 18x 8.5 up front what kind of offsets would i need for regular s13 body
18x9-10 on a stock body is gonna be tuff to pull off unless you pull the rear fenders and slam some crazy camber and have a mean tire stretch. take into consideration the fronts will need the same type fitment considering the width is only .5" difference.
TypeX4Sho wrote:also what would i go with if i wanted to do maybe like a widebody 30mm in the back and 20 mm in the front for them to look good what would be that offset thanks a lot
yes
