poshatch »
https://forums.nicoclub.com/poshatch-u145419.html
Mon Apr 19, 2010 6:34 pm
lol well yeah ill chime back in here, i use rimtuck alot, they give alot of specs and its a great asset lol
im personally on rimtuck, trying to rep the 16's haha xxr 002 the white hatch lol you'll recognize it, and although im not dummy flush ive looked into it alot as well as talked to alot of flush people
50mm overfenders you could run an 10.5 no problem, 11 is possible too, enough camber and stretch anything is possible haha
but it all depends on if the over fenders were put on correctly, i.e. you cut the stock quarter pannel or rolled it out like crazy so that the wheel can travel freely under the over fender
otehrwise your still limited by stock body haha
hit up rim tuck and check it out, if you see nohting you like then hit is back and maybe provide a picture of exactly what you want and then we can tell you exactly what you need by looking at it probably
alot of wheel gurus on here lol but yeah if your looking for dish you got to find the correct wheel, unfortuantely the wheels are expensive like work and ssr would be perfect however they cost roughly 1500 bucks or more haha
tire choice is almost a last step, you get the wheels fit the fitment and camber you want and then determine the absolute minimal stretch you can run and then if you over shot it roll it a little more and if you undershot it then small spacer or a differnt tire combo
you can do 18x10.5 rear and 18x9 or 18x9.5 front, still though a low offset is your friend
