Lies.crzycav86 wrote:oh yeah, russel:
this is allen, the guy that came and sat in your car at FD qualifier fyi.
i know, i'm clarifying this point before i move on to other parts. i figure tires and wheels are the best handling mod possible since its the only contact you have with the road so i start there. and i used the search button to answer my other questions thats why u don't see me posting redundant topics.nismofly wrote:just remember other stuff that will have an effect on handling when choosing your offset, its all one system in the end, and has to all function togther, not in bunches of 1 or 2 parts
well as continental drift mentioned as the offset become more negative the wheel is sitting farther outboard of the car. the wheel now acts as more of a lever then it used to slightly lowering spring rate, and putting more load on the wheel bearings. More extreme cases would have the tires pushing against each other much harder, which I would imagine would lower grip to some level, as well as cause some extra tire wear.AnotherOne-via wrote:what are the other disadvantages besides Clarence to a more positive offset that Exar-Kun hinted at?
you got me there, Like I said I am no expert just read a few books on the subject.People do go 10-15mm lower in offset all the time, and never really seem to notice much. But I personally would imagine that more then an inch (25.4mm)would have to start making SOME difference.I would just do what you want, while keeping in the back of you mind that it would be better to be closer to stock offset then not if you are really worried about it.AnotherOne-via wrote:what would be insane offsets?
Red coupe wrote:I would just do what you want, while keeping in the back of you mind that it would be better to be closer to stock offset then not if you are really worried about it.
who is this Clarence, how did he get in there, and why are you making it seem that i think he is a dissadvantage? i'v never even meet him before.Red coupe wrote: Quote, originally posted by AnotherOne-via » what are the other disadvantages besides Clarence to a more positive offset that Exar-Kun hinted at?
Yeah I ran a spell check with out paying alot of attention...AnotherOne-via wrote:who is this Clarence, how did he get in there, and why are you making it seem that i think he is a dissadvantage? i'v never even meet him before.
It is a dilema. The track increase changes wheel rate for more roll and the wider track will lower weight transfer.InsanityInc wrote:ehh.. the way you're saying some of the body roll stuff is a little odd.
Going to a lower offset will TECHNICALLY improve handling. Going from 35-40mm? I seriously doubt you'll notice a difference. Go from 40-0 and you could probably notice something, but not a while lot.
And going to a lower offset won't increase body roll or weight transfer (body roll IS weight transfer). You'll just get more roll at the edge of your greater handling limit because more force is being applied to your car. It's not really an increase in body roll per-se. You'll have less body roll at any given G figure actually, due to the wider track.
