2011 NICOFEST TOTD Official Registration Information
Read about NICOclub events of the past.
jekl
Car: '93 240sx se coupe, '95 Volvo 850turbo, '09 Toyota Sienna
Cabin Booked! Registry Done! Brake upgrade ordered!
Headed down from Spotsylvania, Va. Will most likely be leaving early Friday morning. I may put some sort of "NICOFEST 2011" logo on the car for other people who will be attending that may take the same route.
NXgear
Car: 91 NX2000
jekl wrote:Cabin Booked! Registry Done! Brake upgrade ordered!
"NICOFEST 2011" or bust! :bigthumb:
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Guess there will only be a hand full of us at the picnic. We will definitely eat good for those that miss out and have some excellent videos of the mile high cherohalla skyway loop run....
Tim Rogers
Car: NX2000 - 4 of them...
EZcheese15 wrote:
NXgear wrote:Just registered today, will have the NX in tow, hopefully not the only 2000 out there. I might have the shortest drive of them all since I'm coming from the Crystal Coast. Looking forward to it!
Sweet man, I love eggs. Had a B14 and B15 SE-R myself.
I'll be doing the Sat. Plan A ride in my '93 NX2000.
I've got a family thing in Bryson City the rest of the weekend so it's the only day I'll be able to join in.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Tim Rogers wrote: I'll be doing the Sat. Plan A ride in my '93 NX2000.
Tim! Awesome you're coming up for it. Haven't seen you in forever.
tigersharkdude
Car: 1999 Nissan Maxima
recently got word that my surgery will be postponed until Oct. 18th, so I would be able to make it to NicoFest.
Anybody need a roomy?
EDIT: I have been offered the floor in a room (will bring air mattress). So, looks like Brad will be there this year :D
tigersharkdude
Found this online, its a pretty good checklist for the tail of the dragon. Its from a Mazda forum (forgot which one exactly)
Recommended Maintenance Checklist for NicoFest at the Dragon
1. Brakes
¨ Brake lines, hoses, and connectors, tight, no leaks or cracks,
(tighten connections or replace lines as necessary)
¨ Brake fluid, clean and clear (should be replaced every 30K miles)
¨ Brake Fluid Reservoir, should show full & no leaks
¨ Check and Replace brake pads as necessary
¨ Check all rotors for wear and condition
2. Tires
¨ Car has 4 tires mounted and one spare tire stored . All tires properly inflated
¨ Tread depth, minimum 3/16” recommended and no wear bars showing
¨ All lug nuts tight and secure on all wheels
3. Clutch
¨ Clutch Pedal, in good working condition
¨ Master Cylinder & Clutch Line Connections, no leaks, all connections tight
¨ Hydraulic Fluid, clean and changed within last 12 months
¨ MC Reservoir, no leaks and filled to proper level
4. Cooling System
¨ Radiator Cap, in place, tight with no leaks.
¨ Thermostat no leaks and installed
¨ Hoses and Overflow tank, no leaks and filled to maximum level
¨ Coolant, changed and system flushed within last 12 months
5. Engine
¨ Belts and Hoses, all drive belts inspected, and properly tensioned
(replace if cracked or worn)
¨ All hoses tight, not leaking or showing signs of wear
(replace if cracked, bulging or with other signs of wear and deterioration)
¨ Engine oil and Oil Filter, recently changed, less than 2K miles, oil at proper level
¨ Battery firmly secured in the engine bay
6. Windshield, windows, and wipers
¨ Wipers, at least one working speed and maintained in good working condition
¨ Glass, clean with no restrictions to good forward and rearward visibility
7. Exterior
¨ All running lights in good working order.
¨ No loose body parts that might cause problems for other cars if they fell off during drives
8. Drivers Compartment
¨ Lap belt and shoulder belt in proper working order, both worn during drives
¨ All items stored in the passenger cabin are properly secured or removed before drives
DrewH
Car: 2006 Altima SE R
2012 G37X
I like this one from last years event... Especially the part about bringing motion sickness pills for passengers. Haha.
What to Bring? - Here is a list complied over the years from Dragon Vets on what to bring to have a enjoyable Cruise.
· FRS Radios (Family Radio Service) set to Channel 7 Subchannel 21
· CB Radio· Camera and Film· Ac/Dc power inverter
· Cash· Digital Camera & Extra memory card
· First Aid Kit· Roadside Kit: tire repairs, compressor, flares, etc.
· Tools· Duct tape· Zip-ties· Jack (not the scissor jack)
· 1or 2 Qt’s of oil· Booze (Graham County is a Dry County)
· Anti-nausea medicine for Passenger on Dragon
· Umbrella and/or Poncho· Good Attitude· Flashlight & Batteries· Folding Chair· Patience
· Detailing Supplies (you guys know who you are….not me
· Window Cleaner and Rags· Bug Spray
· Snacks and Drinks
· Batteries for: Camera, Flashlight, Etc.
· Laptop· Sunscreen
· Evenings can get a little chilly, bring something appropriate
· Wood if you want a bonfire
Nissan / Infiniti Prep Checklist
· Oil – Close to 5K mark on current Oil? Go for an early change.
· Check/Tighten your IC Piping coupler
· Zip-tie all Vacuum lines
· Under Hood Check –Look for leaks, broken/worn engine mounts, worn wires
· Gearbox Oil – If near 2 years or 50K miles - Change
· Brakes – Check Rotors for cracks (x-drilled) and Pads – Have at least 50% left
· Brake Fluid – If near 1 year or 25K miles – Change
· Coolant – If its yellow/green let it mellow, if its brown flush it down!!!
· Tires – Make sure you check your pressure!!! – check for uneven wear
· Wheels – Check Torque on lugs 83ft/lb 1st gen, 102ft/lb 2nd gen <----- Check your FSM for correct specs
· Wipers – Replace blades if older – It could be quite wet
· Lights – Check all lights to verify operation.
· Battery – good condition, make sure is securely fastened. Go to Autozone get a FREE Alternator and Battery check.
· Suspension – Check all bushings for wear, replace as needed
· Steering – Check for wear – replace anything questionable.
· P/S Fluid – Old and Nasty – throw in a cooler if you don’t have the loop.
· Exhaust – Secure with no leaks, check mounts· Heat shields – make sure you shield your BMC, wires and anything else near your manifold/downpipe/turbo etc…
· Wheel Bearings – Check for excessive play
Running The Dragon even at the posted limit taxes all the systems.
318 Turns in rapid succession will find the weaknesses if not attended to ahead of time.
Please be sure to check you braking system well.
maxentropy
Car: '08 Altima Coupe 3.5SE
Good checklists guys, thanks for posting. Gotta replace my brake pads before the trip.
tigersharkdude
I just sent the $20 registration fee in on paypal.
RustspecS13
Car: '74 260z and '88 300zx turbo
Crap, I forgot to call off that friday/saturday. Oh well Ill just call in sick saturday morning. :cool:
I'll register tomorrow, gotta go wrench.
~Alex
tigersharkdude
Would anybody be interested in a decal like this? I can get them made for cheap, only thing is I would need to order them ASAP to have them in time for nicofest
Viper5000
Car: 2009 Altima Coupe 3.5SE/6MT
tigersharkdude wrote:Would anybody be interested in a decal like this? I can get them made for cheap, only thing is I would need to order them ASAP to have them in time for nicofest
Maybe if the font matched.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
The "NICO" part isn't a font, it's a graphic object that just looks like one.
synack7350
Car: nissan '83 720 king cab pickup 2wd 2.4L Z24
I'm def interested in making the trip. any accommodations available instead of fontane looks like they are booked up. I'd like to plus one it but if there's a floor to crash on. I could consider going solo. Someone has to represent the truckers at these things! funds aren't an issue!
tigersharkdude
What time is everybody planning to get there on friday? Im leaving Nashville around 1. Its about 4 hours from here + time change. Should put me there by 7 with a stop or two
NCS13240SX
Car: S13 PROJECT CAR
GONNA REGISTER TONIGHT!!
definitely looking forward to the event im jus here in asheville, so ill be riding over after work on friday and meeting up the rest of the weekend for the events,
hopin the car is done by then, def lookin forward to it
anyone else from the asheville area goin?
BusyBadger
'05 Nissan 350Z
'13 Nissan Juke
NCS13240SX wrote:GONNA REGISTER TONIGHT!!
I'll be heading down from Johnson City and passing through Asheville, hopefully with the rest of the northeast caravan. Jdansmith is coming over from SC and should be able to hook up with the caravan there too. I was thinking a good meeting spot would be just past Asheville, over towards Canton maybe.
NCS13240SX
awesome, im planning on gettin the last few bugs fixed and bein able to ride out there in my ride was gonna say if not someone thats coming through let me know and ill throw some gas in but i wanna be there for sure
and there is a nice meeting spot jus after asheville, exit 44 off of I-40
its candler exit, where i live, lots of food and lil odd ball stuff to hang out for a few before continuing to the dragon.
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
LESS THAN TWO WEEKS!!! :mike
I will be heading down on Friday. Should be about 6-7 hour drive. I will be starting out on the famous "Head on the Dragon". 318 miles and 11 turns... I-71... :squint:
tigersharkdude
I will have my camera with me if ya'll want to get any group pics or want pics of your cars, etc, etc
I posted this on the facebook group page but it doesnt have much traffic, so I will post here as well
Id like to go ahead and let as many people know as possible that I am deaf :( most communication with me will have to be wrote down. I can read lips decently, but if its important please write to me....I do keep a white board or pen and pad of paper with me most of the time
dwada
Car: 91 240sx SE hatch, 91 240sx SE coupe, 95 Infiniti JMF dirty (J30T), 88 2wd toy pickup
Can't wait 4 dis. will be heading up from SC. Sad won't be in a Nissan though rent a turd. All my nissans or infinitis are either dwn or in Hawaii. :frown:
VQpwrdSE-R
Car: 2005 Code Red Nissan Altima SE-R
2013 Nissan Altima SV
dwada wrote: rent a turd. :frown:
Rent a Lotus Elise from Budget!!! :dblthumb: They have a perfomance line rental. That would be a fun, except the $$$$ have no idea what it costs.
maxentropy
VQpwrdSE-R wrote:Rent a Lotus Elise from Budget!!! :dblthumb: They have a perfomance line rental. That would be a fun, except the $$$$ have no idea what it costs.
Pffffffft. Don't listen to him! Rent a GT-R!
tigersharkdude
Just ordered 12 of those decals. They are ~6" long, white with red and blue stripe, and die-cut.
tigersharkdude
ChattCompDoc
Car: 2010 2.5s Nissan Altima Coupe/Crimson Black
How much for decal?
tigersharkdude
They will be about $3 each, just depends on if he sends me extras (usually does). The more I get, the cheaper they will be
dwada
Would but nearest budget is @ Colombia ap. The Elise would prolly be better 4 dragon cuz of lots of turns.
tigersharkdude
6 days left. Seriously, where is everybody at? Id like to get to know some of the attendee's through PM before I get down there, im kind of standoff-ish around people I've never talked to
Return to “Past NICO Events”
