Official CAS Disassembly
Booztd 3
Car: 1990 Nissan 300ZX TT
Guys
This is how you properly disassemble an RB26/RB25/Z32 CAS
The purpose of the disassembly was to install the 24-tooth AEM Disc
This particular write-up will show pictures of a Z32 CAS. The only difference I noticed in taking both RB26 Mitsu and Z32 Mitsu CAS was the 3 screws for the main cover.
Pictured below, begin by removing the 3 screws for the cover. On the Z32, it uses tamper proof screws, the RB just uses regular screws. I used my smallest chisel punch and tapped them until they came loose, and then finished removing them with a large flathead
Once the screws are out, lightly tap the shaft of the CAS, and it will separate from the cover
Next, the dowel pin holding the engagement shaft on to the CAS assembly
I placed the CAS in a small vice where it could not move 'downwards' and used an air hammer with a grinded off punch
You can see I got the dowel to move. I used a small punch to remove it the rest of the way. You may have problems getting the pin out, on the RB CAS, I had to take a die grinder with a cut-off wheel and grind off the flat spot that was holding the dowel in place
Main cover, engagement shaft, dowel pin
Now, the front bearing needs to be removed. I accomplished this by using a small 7mm socket to fit over the 1/2 moon piece that engages the camshaft 1/2 moon. (the CAS below had the indexing key broke off, so i was able to just set the puller right on the intermediate shaft) I then used a small 3 jaw puller purchased from harbor freight for just a few dollars. I had to grind the bottoms off of the jaws so it would fit all the way under the bearing
Here you can see the bearing is removed, next you want to remove the 2 gold screws that hold the intermediate shaft to the main shaft
After removing the 2 small screws, you need to press the main shaft out of the lower bearing. Begin by popping off the rubber Mitsu cover. I used a smaller socket to fit into the bearing and onto the main shaft. Again, I used the small puller to press out the main shaft. I used the small punch to hold the shaft from spinning while I turned the puller
I apologize for the following blurry pic, but after the intermediate shaft is removed, the wheel will come right out. Its held in place by being pressed in between the main shaft and intermediate shaft.
Now install the AEM 24 tooth disc. You can see the disc below. You DO NOT need to remove the actual black part of the sensor. I only did this for educational purposes
Once the disc is in, place the intermediate shaft back onto the main shaft and secure the 2 small gold screws. At this point the main shaft needs to be pressed back into the lower bearing. I accomplished this by placing the front bearing back over the intermediate shaft, and then using a socket, and a vice as a press. Press the bearing on until it seats, and it will continue to press the main shaft into the lower bearing.
After that, you need to install the engagement shaft and the dowel pin. Once again I used the bench vise
Now install main cover and 3 securing screws, as well as the rubber dust cover on the back side. The CAS should spin freely. If not, you dont have the shafts and bearings seated properly.
I had a used leftover Z32 harness that I cut the connector off of, and depinned the RB CAS connector, and then pinned it back into the Z32 connector. Installed on the car, and here is the result
Dont forget to make the necessary software changes that AEM requires
http://forum.aempower.com/forum/index.p ... ttach=6108
The car started right up, and after getting some seat time, the typical 'hiccup' stock CAS sensors have is now gone. The car accels significantly smoother, and I went out and did some 25psi pulls and didnt have a single issue. Hopefully hitting the dyno up friday!
Cheers!
240z4u
Car: '95 Nissan 240SX
Your pictures are 100x better indeed.
Looks good man. Thanks for the tutorial.
eh?
An easier method for those who do not have the tools to remove the pin:
Take a needle nose vice grip to remove the two gold screws beneath the bearing. You can then remove the shaft and slip off the wheel. Add a bit of loctite on re-installation for extra security. I did mine like this 3 years ago with no problems.
stevespeed
Car: RB-Swapped S13, FTW
Awesome write up dude! After reading this I am gona give another look to going AEM instead of Wolf3D
xJLCx
Reviving old thread, the images aren't working. Very good write up, but I am more of a visual learner.
thank you
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I did it for my AEM disc install and it was a HUGE pain in the a**.
RRRRB
Car: 98 RB powered S14
Ive done the AEM disc as well, its not hard once you have done it a coupe times.. initially its a PITA, but Kudos to OP the guide is Helpful
