Official 12/11/05 KC Nissan Meet picture thread
Including ND, SD, NE, KS, OK, MN, IA, MO, and WI
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
We had a blast... See you guys at the next one!
To start us off, Kyle decided he was thirsty:
Well, an hour later he had made some progress: :cheers:
Mike made sure no1 got his last onion ring:
Then Louis got to see his competition, a VH45DETT EP3 civic making 14rwhp... (NO JOKE!)
Now it doesn't look like it has 14rwhp, but it does!
Louis got to looking at his car...
Then out of the blue we heard something coming from his car... so Louis crawled inside to investigate:
Inside he found something, there was a map attached to his engine:
Upon closer inspection, we found it to be a map of a land called Zexnosn2oHNOES!:
Aaron and Bobby are the only two ppl that could read the map, as it was written in both jibberish and redneck.
And then we discovered it wasn't a map, it was lines for ketchup injection:
Then we had a raffle, some ppl won some free stuff, and every1 lived happily ever after until the next Nissan meet.
The EnD? Rly? Rly.
Ryan and Bret after enjoying both a cold and hot burger:
Bret's S13
Bret's urethane-injected engine mounts:
Sandy's good lookin S13 coupe w/ SR:
His motor... the turbo blows Gold... :lol2: :
Clean interior too:
Wheel's sat nice and flush, just wat you'd expect from Nismo
Marcus' S13, lookin clean and shiny:
Some ZzzZzZZ's:
Again:
Bobby's clean 325i:
My dirty-arse car sporting the winter rears:
Marcus got pwnt.
Cold weather discussion huddle:
The difference between USDM and JDM:
Can't wait for the next one guys, thanks for your support!
The rest of the images and slightly larger versions of all pics can be found here:
http://nissaninfiniticlub.net/...age=1
See you in January!
-Dan
CrimsonQ
Car: Purple People Eater
damn, too nasty to get my lazy *** out. Hope for better skies next time
Very cool.
I dig the motor mounts - we need a "ghetto-fabulous low-buck how-to".
Import_Ant
AZhitman wrote:Very cool.
just pretend the house is a car
http://mfile.akamai.com/9330/w...k.asx
I'm probably going to do this when I start working on the fastback again, I'll have to take pics when I do.
Dano
Aaron (CA18DET_boy) said he was going to be doing this soon so i'll see if he can document it.
-Dan
Pretty sure that's not the same stuff.
I've used the stuff in the vid, and even dry it's pretty soft and crushable.
Import_Ant
sorry I was feeling goofy yesterday. that Great Stuff is only good as a sound dampener you're right. I'm guessing he used Urethane foam.
SilviaSativa
Car: '93 240sx
I got the polyurethane from Home Dehoe, the only caulking tube listed as 100% polyurethane. The brand is PL, and in a yellow and black tube. I don't remember if I used one or two of them, but I only filled the motor mounts since I had trans mount from SPL Parts..
I drilled like a 1/4" hole in the mounts, and tried to drain as much of the fluid as possible, and cleaned them up from dirt and grease. Then, just inject with polyurethane until it oozes out the hole. I prolly should've just left it at that, but went ahead and filled up the entire mount. Definitely let it dry a couple days, and I let it soak up the sunrays to speed up the process!
SOLID! The car rattles like a mofo! All the old timers at the workplace give me **** for the ghettofied mounts!
I I filled one and my brother did the other, his turned out much cleaner! The mount I filled is the one in the pic I should've sprayed 'em black too!
youngmanvr4
Car: 94 3000GT VR-4/90 240sx
I love Sandy's wheels.
I wish I could have been there and meet you all since I got my project most of the way done (dang power steering). Now its going to be april before I'm even in Kansas to have a meet. Unless its before the 5th of Jan. Oh well, always next year lol.
How the hell did I miss this?
Dano
No clue
-Dan
Return to “Midwest Region”
