bmadd2402 »
https://forums.nicoclub.com/bmadd2402-u23099.html
Wed Jan 17, 2007 1:02 pm
I swear it, I was on, and everything lined up. I must have turned the crank 5 times to make sure!!! Could a loose tensioiner cause you to jump a tooth? Now I need to do a damage assessment. I was thinking to re do the timing belt, get everything back together, and do a compression test, and that should tell me if there is any internal damage, right? Any other way of checking things out?
