OEM Wheels, please add info
Rex
Car: None
Looking to collect as much "reliable" data as possible on Nissan and Infiniti OEM wheels. Please post up what info you have and if possible your reference for such.
Size, offsets, tire size recos and weights AND pics of them on cars if you can.
Once this is all collected we'll migrate it into a thread with just the info or maybe even an article. Thanks.
bmwkiller
Car: '90 Q
Just a thought --- I recently went through the process of trying to find wheels for my car and I found it hard to envision what would actually look good on the car vs. what looks good just sitting in a box (see the thread "got pics of your wheels").If maybe in the article you could include a pic of the various wheels on an actual car, that would be cool for the next person looking.
Rex
Car: None
Great idea, I'll add it to the original post.
CrimsonQ
Car: Purple People Eater
good idea, btw I was lurking in the J30/M30 section today and noticed that they have this........zerothread?id=148053
We could really really use a section like that
Q_SHIP
Car: 1999 Q45T with a billion miles.
not bad^
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
Original OEM "Pie Pans" for 90-93(?) specs...
15x6.5JJ45mm offset
OEM tires
215/65r15 96v
szh
Car: 2018 Tesla Model 3.
ceningolmo wrote:OEM tires
215/65r15 96v
I think the original tires on my 1991 Q45 were 95 load index, not 96, but am not absolutely certain of that. They were Michelin XGTV and no longer available. The replacement Michelin Pilot XGTV is a useless tire in wet weather.
Z
qship96
Car: 1996 Infiniti Q45
Z
the pilot xgtv has also been replaced with the exalto series, which are v rated in 225.60.15 size and are a huge improvment to the xgt h and v series{ have run the xgt in both h and v versions for the last 130,000+ miles on my q,and now the exaltos-highly recommend them to q owners
ceningolmo
You know... you are probably correct. I took that info from the electronic FSM which started in 93(?).
Let me check my hard copy...Yep, you are right. Everything is listed identically with exception of load rating. 95v
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Ok, here's one.
FYG33 standard wheel
Cast aluminum, 20 hole
16x7JJ
+40mm offset
21.7 lbs.
Load capacity unknown.
97Q45t
Car: Viper RT/10, Ford Explorer 4WD
1997-1998 Q45 touring wheel:
Five-spoke performance cast aluminum alloy wheel16x7JJ+40mm offset20 lbs. (used bathroom scale)215/60R16 94V
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
One of our scales is off, Duy.
Q451990
maxnix wrote:Ok, here's one.
16x7JJ
+40mm offset
21.7 lbs.
And a pic of them on a G50
bmwkiller
Car: '90 Q
szhosain wrote:I think the original tires on my 1991 Q45 were 95 load index, not 96
The owners manual for my '93 indicates a rating of 95.
97Q45t
maxnix wrote:One of our scales is off, Duy.
Brian, the Touring wheel must be lighter. If not Nissan wouldn't called it "performance" wheel.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
97Q45t wrote:Brian, the Touring wheel must be lighter. If not Nissan wouldn't called it "performance" wheel.
Yep, different wheel, same size. Weird. Did you see aload rating on yours? Couldn't find one on mine.
Hey Duy, any chance of throwing one of these banners up on the page? Looks awesome, btw!
zerothread?id=149496
bmwkiller
Car: '90 Q
No info on bolt patterns, offsets, or center bore (there's other sites for that), but at a minimum this site has a pic of almost every Nissan & Infiniti wheel and basic size info. I know it would be a lot of work for you to go through it all, but for those posting it might give a good reference.
http://www.wheelcollision.com/cta.htm
97Q45t
Brian,I didn't see the load rating on my wheels neither.
Greg,Thanks. I will post the links with the banners inserted in the other thread.
bmwkiller
Car: '90 Q
Rex wrote:Please post up what info you have and if possible your reference for such. Size, offsets, tire size recos and weights AND pics...
Just picked up a set of Nissan Murano wheels, and this is what I've got so far: Size - 18x7.5 (stamped on the wheel)Offset - 35 (stamped on the wheel)Weight - 26 lbs. 10 oz. with center cap & valve stem (acording to my friendly neighborhood UPS dropoff center who presumably has a pretty accurate scale)
Once I get tires and get these on the car I'll post tire size and a pic. In the meantime, someone has already posted a pic of these wheels on their '97 (zerofile/25371/1.jpg).
nchopp
Piepans, '93.
15x6.5JJ45mm offset
Rex
Car: None
350Z Tire SizingStandard 17":F-225/50WR17R-235/50WR17Touring 18":F-225/45WR18R-245/45WR18Track 18":F-225/45WR18R-245/45WR18
350Z WheelsStandard 17":Alum AlloyF-17x7.523.259lbsR-17x824.140lbsTouring 18":Alum AlloyF-18x8R-18x826.565 lbsTrack 18":Super-light Alum AlloyF-18x818.188lbsR-18x8.518.629lbs
350Z Offsets:Standard 17":F-.30R-.33Touring 18":F-.30R-.30Track 18":F-.30R-.33
Rex
Car: None
G35 Coupe Rays 19" rears19x8.5 jj 33 offsetRays Eng
