OEM wheel studs?
texas_s13
Car: 90 240sx hatch and a 92 coupe
I just wanted to know how long the stock s13 wheel studs are, because i need to get spacers and longer wheel studs, so my wheels dont rub against my struts, and need to know if in need the 50mm or 60mm nismo wheel studs.... thanks
crzycav86
Car: 93 Nissan 240SX KAT
I don't really know how long they are(I can check later) but I do know that my 8mm spacers wouldn't fit without aftermarket studs. 5mm is the biggest that would be safe on stock studs.
I'll check the size of the stock studs if I can find them.
chmercer
just get the 60s and some open ended lugnuts
60's are good up to approx 15mm.
I believe stock are 45mm.
