OEM Wheel Info. Specs, weight and part numbers
EdBwoy
2021 Edit:
I would like this thread to be a repository of information to help the community, much like forums were meant to do. To help me keep it somewhat organized and standardized, the topic has been LOCKED, but I will still be able to receive information either by PM or email.
Contact me to share any info that you might have, or to correct any issues you find with the info posted.
[email protected] is the best way to reach me, plus it's much easier to share pictures that way.
This is the basic format I shall be using:
1. Wheel type/name and Donor Vehicle
2. Diameter x Width (Inches x Inches)
3. Offset (millimeters)
4. Weight (Pounds)
5. Misc information
Here is the Masterlist (I will keep adding to it with time)
Infiniti M and Q70 wheels
2003 - 2004. Infiniti M45 Click Here
2006 - 2007. Infiniti M35 and M45 Click Here
2006 - 2007. Infiniti M35 and M45 Sport Click Here
2008 - 2010. Infiniti M35 and M45 Click Here
2008 - 2010. Infiniti M35 and M45 Sport Click Here
2011 - 2014. Infiniti M, Q70 Base model wheel Click Here
2011 - 2019. Infiniti M, Q70 Optional 18" wheel Click Here
2011 - 2019. Infiniti M, Q70 Sport split 5-spoke wheel Click Here
2015 - 2019. Infiniti Q70 Base model double 5-spoke wheel Click Here
2016 - 2019. Infiniti Q70 Premium Select model 15-spoke wheel Click Here
2019. Infiniti Q70 Long Wheelbase double 10-spoke wheel Click Here
EdBwoy
Reserve
EdBwoy
Infiniti M45
2003 - 2004, all trims
18 x 7.5 inches
offset 35
no weight info
part # 40300-CR925, 40300-CR926
Tire size 235/45/18
EdBwoy
2006 - 2007, Base models and AWD
18 x 8 inches
offset 47
25 pounds
part # 40300-EH026, 40300-EH027, 40300-EH028
Tire size 245/45/18
EdBwoy
2006 - 2007, Sport models
19 x 8.5 inches
offset 50
26 pounds
part # D0300-EG54A
Tire size 245/40/19
EdBwoy
2008 - 2010, Base models and AWD
18 x 8 inches
offset 47
no weight info
part # D0300-EJ73A
Tire size 245/45/18
EdBwoy
2008 - 2010, Sport models
19 x 8.5 inches
offset 50
26 pounds
part # D0C00-EJ94A
Tire size 245/40/19
EdBwoy
Infiniti M37, M56, M35 hybrid and Q70
2011 - 2014, Base models and AWD
18 x 8 inches
offset 43
27.2 pounds
part # D0C00-1MM1A (silver), D0C00-1MM4A (metallic)
Tire size 245/50/18
EdBwoy
Infiniti M37, M56, M35 hybrid and Q70.
2011 - 2019, optional wheel for the platform but is most common on the hybrid models
18 x 8 inches
offset 43
no weight info
part # D0300-1M025
Tire size 245/50/18
EdBwoy
2011 - 2019, Standard on sport models, it was later offered as part of the wheel + tire upgrade.
Tire size 245/40/20
Wheel specs:
20 x 9 inches
offset 43
32.7 pounds
part # D0C00-1MA4A, replaced by D0C00-1MU4A
Note: this wheel is also sold as an accessory wheel, gray in color, which is part # D0300-1MU9J
EdBwoy
Infiniti Q70 and Q70 hybrid
2015 - 2019, standard 18" double 5-spoke wheel
18 x 8 inches
offset 43
no weight info
part # D0CMM-3ZF4A
Tire size 245/50/18
EdBwoy
15-spoke 20" wheel
20 x 9 inches
offset 43
32.8 pounds
part # D0CMM-1A37A
Tire size 245/40/20
EdBwoy
Infiniti Q70 long wheelbase
Double 10-spoke 18-inch wheel
18 x 8 inches
offset 43
no weight info
part # D0CMM-1PM3A
Tire size 245/50/18
