OEM water pump noise
benjamin725
Car: 96 240 se 92 240
I just installed new; OEM Tbelt, OEM tensior, OEM idler, OEM water pump. Followed FSM to the T. Started to bleed the system, then right when it got to 150F, i heard a high pitch squealing noise from the Water pump. After 15 min it kinda went away, but still alittle noticable. Just wondering if there's some wierd break in period( doubt it) or maybe it was a storage issue. Any thoughts will help.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Is the belt tight enough?
benjamin725
yes it is, i thought it might be too tight but i loosen it n nothing changed
Darius
Did you replace your timing belt tensioner and idler when you replaced your timing belt?
Shocker
Car: 89 240sxHB rb26/30
he already stated that above... possibly over tightened your timing belt... might want to check that out. Remove the timing cover and inspect.
midnightsliding
Darius wrote:Is the belt tight enough?
benjamin725 wrote:yes it is, i thought it might be too tight but i loosen it n nothing changed
Shocker
Yeah but what belt did he loosen? Never specified.. the accessory belt? or timing?
benjamin725
well today at work i ran the car till started to make that noise ( faint high pitch squealing). I took off the water pump belt off and it went away. I quess i'll be calling nismo to have alittle chat about this.
