climate-control-problem-left-side-blows ... 94185.html
Recently my factory evaporator was replaced with an aftermarket evaporator ($65 - $100 US). (An OEM evaporator is $375! with discount ) The factory evaporator failed when the expansion valve was being replaced.
BUT now, my AC blows much warmer on the left side than the right side. ANd significant troubleshooting suggests everything in the HVAC is working "right", leading me to the question whether the aftermarket part performs poorly versus the OEM part.
Here is what I've come up with:
http://www.refrigtech.com/Knowledge_Cen ... System.pdf
The drop in air temperature is greatest across the first row of the coil and diminishes as the air passes across each succeeding row. The fact that the temperature difference between the air and the refrigerant is greatest across the first row, and becomes less and less as the temperature of the air is reduced in passing across each succeeding row. The temperature difference is least across the last row of the coil.
- It's a fact, evaporator temp varies across the fins - but by how much in this application?
From: http://www.achrnews.com/articles/87135- ... oil-debate
"one of the biggest problems with aluminum is that leaks can occur where the aluminum meets the copper in the condensing unit due to galvanic action."
- So copper parts are more likely to fail than pure aluminum - I have heard that all aluminum evaporators are very reliable. Could copper be responsible for the factory evaporator being prone to failure?
“Aluminum is roughly the same price per pound as copper, but you use three times as much copper in a copper coil. It does have an impact on manufacturing costs,”
- It's much cheaper to use aluminum than copper. Should I assume the aftermarket part is aluminum? probably
From an article on Wikipedia titled : "Copper in Heat Exchangers”.
Scrolling down to Thermal Conductivity it reads : Silver - 247.87, Copper- 231, Gold - 183, Aluminum – 136.
- Copper is 59% more thermally efficient than Aluminum!
- Copper tubing is also thicker than aluminum, to further increasing the side-to-side thermal conductivity
==> is the factory evaporator made of copper or aluminum? And is the OEM replacement part also made of copper?
==> Any insights on whether this theory makes sense, or am I prone to dreaming up technical conspiracies?
THANKS!
Added info:
Here are two pics of a used OEM evaporator:
and here is a pic of a new UAC aftermarket evaporator:
note: I'd also expect that thinner aluminum evaporator cores cool down the car quicker than thicker copper tubes
